Lifting your Boat Safely
Walt: From what you have written, I believe that you must have something to attach the cleats to. As the others have written, I wouldn't recommend picking up your boat by the cleats, even if the plastic ones were replaced with metal ones, and they were backed-up with aluminum plates. I do lift my boat up. I have looked through the archives for you and found the link below that shows my boat lifted in my wife's dad's truck garage. Please open the photo shown at the bottom of that page. I have since purchased the web slings that I was asking about at the time I wrote that forum article, and they are OK. I would probably get the 4 inch ones if I were to buy them again, but the 3 inch ones that I bought do work fine. I still pad them with carpet to keep from scratching the hull, but don't use the 1/4 inch paneling that I used when we lifted the boat with chain. I have also bought 3, 1 ton winches to use to lift the boat. (My wife's dad already had a little 3 ton winch, and they had several giant winches that must weigh about 60 or 70 lbs. That's what I used when the photo was taken. You can see one in the rafters on the right side of the photo.) I bought the 3 new 1 ton winches at Harbor Freight because they are light and small and cheap. I actually didn't have to lift my boat this year, because the paint only needed touched-up. I now use only ablative paint. I have been in my boat when it was suspended as shown in the photo, and have, of course, been under it for hours, preparing it and painting it. Every component that I use to lift it has at least 1 ton tensile strength, so if the boat only weighs about 1 ton, I have a safety factor of 4. I don't recommend that you go any less than that, and also make sure that the building that you are connecting your winches to is adequate. You don't want to get crushed, or have your boat smashed if it falls when you have it suspended. I have picked my boat up as shown in the photo many times, so if you have any questions, just reply. Aldo
