I own a Beneteau 331 purchased new 3 years ago. The lifting keel failed when the boat was 1 year old due to electrolitic corrosion of the main nut. 2 years later it failed again, the jock screw unscrewed itself from the nut. The boat was lifted out and repaired, 2 weeks later the same happens! No undue force was used.Is this a common problem? Is there a design fault? Is there a permanent cure?
