Lifting a Hunter 23 with straps
11
Hunter Hunter 27 St-Blaise-sur-Richelieu
Dood day All,
I did to know where you need to put straps Under a Hnuter 23.5 (1991) in order to take it out of the water?
Is there any information on this somewhere
Thank you
KD3PC
1,069
boatless rainbow Callao, VA
there are usually small diamond or triangle stickers just under the toe rail to show where lifting gear is set....
hopefully a 23 owner will chime in...
Oct 6, 2008
857
Hunter, Island Packet, Catalina, San Juan 26,38,22,23 Kettle Falls, Washington
If the boat lacks ID. marks for lifting points then either place the slings under bulkheads or approximately 1 foot or slightly more in front of and aft of the keel. I prefer the bulkhead position. Water ballasted boats should be lifted at bulkheads where weight is not put on the ballast tank. I lifted my H260 on the marks that were on the hull.
I haven't lifted a H23 but I've lifted a lot of boats under 26 feet.
Ray
-na -NA Anywhere USA
what ever you do when lifting a boat, always tie the straps together so they will not slip out from beneath the boat. I have seen many boats fall and damaged as a person or the yard did not take this extra safety measure. Remember the hull is curved longwise.
