lifting a Hunter 19
Mar 13, 2008
2
Hunter 19_93-96 Big Pine Key
I'm selling my 93 Hunter 19. The prospective buyer wants to lift it with "davits". Basically attach wire or cable fore and aft. Does anyone know where the "lift points" are and how does one avoid the rigging?
Hunter 37 C sloop Punta Gorda FL
Friends of mine lift small boats with straps under the hull and a board or I beam called a spreader bar to keep the straps from coming together if the use a single davit. Not required with two davits, straps will stay at or near distance between davits.
-na -NA Anywhere USA
That boat is a Hunter 19 water ballast which I was the top dealer who sold the most with the most experience and knowledge on what to do. Wire or straps underneath that hull will indent the hull with the boat sitting for a long time in that situation. In addition it will affect the tank lid integrity possible busting the seal.
The best advice is to follow the bunkboards as it appears on the trailer for a boat of this type to sit in a lift with the boards facing flat against the hull. . Otherwise the owner will be sorry.
