Lift Replacement
I recently replaced the two stair lifts on our 373. I purchased them at Auto Zone. Make sure you take one of the pistons to match the size. Since the new pistons have an end for a ball joint, which comes with the particular lifts that I purchased, I took the brackets off of the boat and drilled out the original pins. With the new pins mounted in the brackets, I reinstalled them on the boat. Lifts fit perfectly and work great.
