Replaced the lifelines over the weekend. Used 100 feet of 1/8 inch 1 by 19 no 314 stainless, with solid (cast) thimbles at each end. Supplies from riggingonly.com - $100. I nicopressed the ends using two sleeves. Used a Dremel tool with cut off wheel for cutting- neat and easy. Placed one sleeve, pressed it, cut the wire so the second sleeve would cover the cut - no meathooks. No turnbuckles - I lashed the lifelines to the aft pulpit shackles with 3/16 sta set braid, and sewed the knots to make sure they won't untie. (Cheaper, and the lifelines can be slacked in a jiffy (to get a man over the rail) by cutting.)
Whole job came in at a low price and is seamanlike.Nicholas Walsh
Nicholas H. Walsh P.A.
111 Commercial Street
Portland Maine 04101
Tel. 207/772-2191
fax 207/774-3940
This email was sent from the law firm of Nicholas H. Walsh P.A. It may contain information that is privileged and confidential. If you suspect that you were not intended to receive this email, please delete it and notify us as soon as possible. Thank you.[Non-text portions of this message have been removed]
Tel. 207/772-2191
fax 207/774-3940
