Lifeline battery terminals.
Apr 16, 2018
1
Hunter Legend 35.5 Tierra Verde
This weekend while rewiring my external regulator. I unscrewed the terminal positive bolts on the Lifeline 6v AGM. And of course dropped it into the abyss. Lifeline technically manner states copper alloy M8 part number 6923. I've looked over the WWW for this part with no luck. My next step will be to call the manufacturer. But my question is what can I do as a temp fix so that I can be assured the bilge and few other critical services aren't without power. I tried a 5/16 stainless steel bolt but was unable to get it to screw more than a quarter inch. Any suggestion or help as to where I can find the terminal kit is much appreciated.
@Mike03fla Your bolt had the wrong thread. I am guessing you only lost one and the other can be removed from the battery and taken to a shop to be matched. You can try a Napa dealer. They are likely to have an exact match. You can also look for a lifeline dealer online and they may have a replacement.
