Stanchions
Do you already have stanchions but just no lifelines? I agree with David in using 3 strand line for the lifelines. I did this on my now former (*sniff*) C27 and it worked GREAT! I bought nice "classic" bronze pelican hooks that had an eye at the end and spliced one end of the line to it then attached it to the "gate" (pushpit). I then led the line thru the holes in the stanchions to the connecting point on the pulpit and stretched it as tight as my little girly arms could get it. I marked the "middle" of that splice's eye, meaning the point at which the line bends thru the bail & comes out the other side. This way I knew exactly where to splice. I unhooked the pelican hook and then spliced the "permenent" end onto the pulpit, making sure that mark was right in the middle. When I was done, I had a nice, tight lifeline. It took no more than a couple hours for both, assuming you know how to splice. BTW, if they get a little saggy over time, all you have to do is unhook them, wet them down and let them dry. They'll tighten right back up again!LaDonna
