Life line post
May 13, 2017
1
Hunter 38 Lake Champlain
I would like to tighten the life line posts on my Hunter 38 , 2006. Do we have to remove all the interior ceiling to be able to reach the nut?
Thank you for your help.
Mar 26, 2011
3,749
Corsair F-24 MK I Deale, MD
a. If it is loose, you probably need to remove it and re-bad. It is almost certainly leaking.
b. Search "stanchion" and you will find many threads.
Re. Hunters, I'm sorry, but I do not know. Best of luck.
Dec 2, 2003
765
Hunter 260 winnipeg, Manitoba
Your hunter will likely have an embedded aluminum plate that the stanchion bolts thread into. If you have any nuts on the stanchion bolts I would expect that to be something the previous owner had done. I would concur about rebedding the hardware - get some of Mainesails butyl tape to do the job.
Oct 29, 2005
2,363
If stock setup mostly likely no nut just threaded metal plate embedded in fibreglass. If thread is striped you may need to rethread one size up and use new upsize screw.
