Lexan window replacement
ryansk
Nov 24, 2015
21
hunter 27 oologah
Good morning,
I have a 1992 H27. While removing the port frame in the head, the lexan window that it was fastened to broke along the bottom. Is that window something that is available to purchase or should I try to remove it in one piece and have a new one cut? Also, Any tips or trick to removing replacing the lexan?
Thanks in advance.
Ryan
Likes: All U Get
Oct 24, 2010
2,405
Hunter 30 Everett, WA
Pictures might help. It should be pretty simple if it looks like ours.
Ken
Good morning,
Thanks in advance.
Ryan
I think you can buy the lexan here on the SBO site. You will probably have to call them and they will hunt it down for you. I attached two PDF's that talk about how to do this job. Once specifically talks about how to get the window off the boat. Good luck
If you go to the Hunterowners.com section of SBO, you can find a bunch more manuals. Those were loaded under H26 but you can search by model number also.
Likes: ryansk
