Lexan skylight thickness
Rich
I've a Legend 35.5. I need to replace at least one of the skylights. How thick is the lexan material...anyone out there know?
Rick D
Jun 14, 2008
7,183
Rich, Did You Check Hunter As An OEM Source?
I called them about the same question and found they could supply them for less then what the local source was going to charge. I never did find the thickness, but they are acrylic, not lexan. There was a thread long ago from Jim Bohart about the reason for acrylic vs. lexan and it made good sense. Rick D.
Mike Webster
Skylight replacement parts
The window material on my 32' Hunter Vision is 7/16" thick. You should call Mike Thomas at Hunter Marine (1-800-771-5556, X3015). My side windows were originally done by Spartech, and they still had the patterns. However, they would only sell thru Hunter, not direct. As a guide, they are $296 ea, with a 4 week delivery. Your's may or may not have been made by Spartech, but Mike should know. I find prices from Hunter to be very competitive. Also, if you buy them locally, you will have to remove the windows and send them to your fabricator for matching. Good luck.
