Lexan port panels
5
2 272LE Middle River, MD
Looking for recommendations for replacing port panels on an O'Day 322. Are these custom only? Are they still available? Are they flat enough to cut from a sheet of lexan?
Mar 9, 2009
12
2 322 Kemah TX
You will have to have them custom made locally. Not hard to do. The material is 2412 Bronze Lexan 1/4" thick. I am fixing to start having mine replaced with 3/8" thick lexan.
Goodluck,
Lon
Jan 27, 2008
3,092
ODay 35 Beaufort, NC
Available pre cut
Go to D&R Marine. Rudy has them on his web site for sale.
jojanlev
Lexan panels
Contact Rudy at D&R in assonnet MA
Has all parts for O'Day and gives great advice for installation
Jun 2, 2004
1,950
Oday Day Sailer Wareham, MA
I was down visiting Rudy last Saturday, the pattern for those panels was hanging on the wall I think!
Aug 18, 2006
2
- - Charlotte
I ordered some Lexan windows for my 272 from Rudy, and followed his instructions carefully. Unfortunately, several of them have cracked a couple months after installation, with the cracks generally starting at the screw holes. The material looks thinner than the original windows, and I wonder if anyone has a suggestion for different material, or how to prevent those cracks.
Feb 6, 1998
11,724
Lexan vs. Acrylic
Guys you don't need to take my word for this. Below are some quotes from Tony D'andrea who is the Acrylic & Polycarb guru in the marine industry. He is the Nigel Calder of portlights and hatches and owns the largest hatch warranty & repair facility in the world called Select Plastics. Before starting Select Plastics in 1994 Tony was the national sales manager for Cyro Plastics the makers of Acrylite GP and one of the largest produces of cast acrylic. Tony is also an adviser to the ABYC on all things plastic and consults to industry including many of the hatch and portlight manufacturers. In short he knows his business.
Tony on Acrylic vs. Polycarbonate:
"Consider the Following:
All major hatch, portlight and window manufacturers use Acrylic in offshore / bluewater marine products. Acrylic is more scratch resistant than standard (9034) polycarbonate.
Acrylic is significantly more durable when exposed to Ultra Violet radiation (sunlight).
Acrylic is less expensive than Polycarbonate.
Don't misunderstand my preference for acrylic. I buy, use and sell a significant amount of both products and each has its application. In my humble opinion Acrylic is more durable, versatile and cost effective in the hands of a skilled craftsman than polycarbonate.
Additional considerations may include polycarbonate with UV and scratch resistant coatings. While these products are heavily promoted by several manufacturers and carry 5, 10 even 15 year warranties the following information has been reported in "real life"applications:
Polycarbonate is impact resistant. When its new it is almost impossible to break.
[*]Small quantities (less than a 4 by 8) in gauges over 1/8th inch are difficult to to find in the uv/scratch resistant grades.
Colors are limited. Only two standards (gray and bronze).
Try and find anything thicker than 1/4 in UV/ scratch resistant!
Polycarbonate foreshortens when subject to static or dynamic loads. What this means is if you replace your hatch lens with polycarb, seal it and then step on it the ductile material will deflect (bow) in the center. One of two things may happen. 1st you will surely break the watertight seal, 2nd you may end up with a leg in your galley.
As for the warranty: The original owner is warranted against failure subject to the material being submitted to the distributor for evaluation with the original invoice subject to actual replacement cost at the time of purchase. I guess this means they sell you a new square of material and apply the old payment to the new cost. How about the labor to fabricate the part, install it and sealant? Why take the chance?
Polycarbonate is a great material, The US Air force uses it for fighter canopies! I sell Polycarb to the USCG and US Navy. Remember they don't mind using it because we are paying to replace it every three years.
Both Acrylic and Polycarbonate have specific uses and installation requirements.
Cast Acrylic (of a specific thickness) is in accordance with CE and ABYC guidelines, and installed on virtually all of the big blue water sail boats produced on both sides of the pond. Polycarbonate is commonly used as a replacement due to its ease of fabrication and incredible initial strength. The USCG and USN require Polycarbonate on their vessels but they also have a PM cycle of 36 to 42 months for change out. My Tax dollars at work...
Due to its ductility Polycarbonate it is more challenging to install. I have seen Sika Flex 295UV with primer and Dow 795 both mentioned. I use and recommend both. Dont go over 4 ft continuous length with a fixed portlight. Remember the coefficiant of thermal expansion for Acrylic and Polycarbonate is in the neiborhood of .000039 per inch per degree F. That means an 8ft plastic port will expand and contract up to 1/2 of an inch from the coldest day in Feb to the hottest day in summer. WOW!! Compartmentalize the job. It will be easier to install and less prone to leaks.
Never ever bolt a plastic portlight in place. Screws are fine to hold a lens till the adhesive cures. Take them out asap and fill the holes with the afformentioned products. Both of these products are rated at 700 + percent elongation before tear.
Strong flexible and UV resistant.
Been to a boat show lately? Seen any screws? Glass is good so long as your boat does not twist or torque. Show me a fiberglass boat that does not twist and I will show you a cocktail barge tied to the dock.
Tony on Sealants:
"I hear the question as to which sealant to use when bonding Acrylic, or Polycarbonate to aluminum, stainless or FRP over and over and over.....
Well here goes... The only three adhesives I would consider using are Sika Flex 295 UV with the primer, GE SG-4000, and Dow 795. Using the correct adhesive is only 1/2 the battle. Do not apply the sealants below 50 degrees F. The temperature must maintain at least 50F during the entire 21 day cure cycle. Cut this corner and your finished before you start. Preparation of the bond area is also very/ very important. DO NOT TOUCH THE BOND AREA WITH YOUR BARE HANDS! Contamination from the dirt and skin oils will make a solid cure impossible. You may clean the FRP and metal with acetone to prep the area but if you touch the Lexan or Plexi with harsh solvents you will ruin the portlight. A 50/50 mix of isopropal alcohol and distilled water will work well to clean the plastic if needed. Remember that clean enough is not clean enough."
