Ron Dague
I have numerous ports in which the "plastic" has clouded or crazed. I've previously followed the discussion on what to do with acrylic and Lexan. Here's my question: Does anyone know an easy way to tell if a "plastic" window is lexan or acrylic?I believe that "Plexiglass", is a trade name for one manufacturer's acrylic. I've read that I might be able to buff out some of the surface cloudiness and crazing in acrylic window. Lexan will need to be heated, probably by someone that knows what they are doing. And neither technique will make the windows look quite like new!Finally, knowing that Lexan, in thicker versions, is bulletproof, I thought about taking a smaller caliber handgun and ... But, as a testing procedure, it might go through the window (and the hull!) if the window is acrylic, so please, no testing procedures involving pyrotechnics!And although I've cruised the archives, any foolproof advice on making my windows look like new, will be welcome!Thanks in advance,RonS/V Finesse, h34www.ExploreScuba.com
