Lewmar Super hatch update and question
MitchK
Sep 22, 2017
102
Capital Yachts Newport 28 Burbank, WA
Well, I finished installing the new lens in the Lewmar Super hatch on our N28. I replaced the hatch to frame seal too. I ended up using 1/2" thick cell cast acrylic to make the new lens. The original used a thin seal of butyl between the lens and frame, then the gap between the inside edge of the lens and frame was filled with some sort of sealant. All of which had failed.
The original lens was 10mm thick. I could not get a piece of 10mm, so I went with 1/2" cell cast acrylic.
Instead of the thin butyl between the lens and frame, I used Dow 995 structural adhesive, and filled the edge gap with Dow 795. Both are designed to attach and seal window glazings to the frames. I also sanded the area of the lens that sits in the frame for better adhesion. Its not perfect, but all in all it turned out fine. Hopefully the Dow products will keep it all sealed up.
I am getting ready to re-install the new lens/frame back onto the boat. I have one more question to resolve before I do. The hinges that attach the hatch to the lower frame is made of two aluminum flat arms. These arms bolt to the new acrylic lens. When I removed mine, there was no seal of any sort between the lens and the hinge arms. For those of you that have rebuilt their hatches, what type of seal did you use between the hinges and the lens? I am considering making a couple of flat gaskets out of either neoprene or EDPM rubber to fit between the hinge arms and the acrylic. I will probably used some butyl around the screw threads to seal the screws to the T nuts. That should make a nice long lasting water tight seal. Any comments on your experiences would be greatly appreciated.
3,972
Order up a roll of Maine Sail butyl. To say that you will not be disappointed is quite possibly a serious understatement.
MitchK
Sep 22, 2017
102
Meriachee,
I have a roll of Mainsails Butyl. I have chosen not to use it for the primary seal between the acrylic and hinges. I do plan on using it around the screws that attach the hinges to the acrylic. I am trying to figure out what to use between the hinge and the acrylic to cushion and protect the acrylic during use, and expansion/contraction due to heating/cooling. Acrylic expands quite a bit due to temperature. At this point, I am going to use a piece of EDPM between the hinge and acrylic, and butyl around the screws to seal them. Hopefully someone who had done this job will weigh in and let me know what they did, and how it turned out.
MitchK
Sep 22, 2017
102
Ok, I finally finished the install of the new lens. I ended up machining a new set of T nuts patterned after the original out of some bronze round stock I had. They are not perfect, but will do the job. I ended up using the same metric (6 x 1.0) screws as was originally used. I made the barrel a little longer since I used 1/2 acrylic instead of the original 10mm. Also, the stainless screws I found are a socket head. Not my first choice, but I was running out of time, and wanted to get the hatch re-installed. I used a piece of EDPM rubber between the hinges and acrylic with a ring of butyl around the screw so that it filled in the gap between the hinge and the T nut. All in all, it went well. It also looks great!. Nice to be able to open the hatch and get a little extra ventilation. The original hing rubber still holds the hatch in the open position. Next big project is the rebuild of the sliding hatch.
472
1984 Oday 39 79 Milwaukee
I have recently re-done three of my Superhatches. Oddly, the smallest of my hatches had thicker acrylic than the large hatches. The acrylic I got is just slightly thinner than the acrylic in the large hatches, .354mm where the originals were 3/8". I bedded them in black butyl tape, and sealed around the perimeter with Dow 795, replacing the rubber seals in the process. For the hinges, I just created a small bevel in the acrylic and used a butyl ring only around the fasteners. I also replaced the o-rings on the handles. I used the old acrylic to trace a pattern on the new, then cut it out just outside the lines using a jigsaw with a blade for plastics. I then clamped the two together and used a router with a pattern bit to get them exact. I ground a couple of drill bits to a much steeper angle and drilled some test holes in some scrap pieces to make sure they didn't grab. Cleaning the old sealant and butyl off the frames was the worst part of the job. My larger hatches are in need of new keepers, but they are pretty spendy from Hatchmasters.
2,245
A number of years ago I had to replace both of our hatches, a size 70 and a 20.
The larger hatch had a bent frame, courtesy of the PO. It was just as well to start over.... those old "roll stop" hinge assemblies were a poor design. Whoever designed them should be shot. Out of a cannon. Into the sun.
Your workmanship looks really good, and no way could I do as well.
Aug 21, 2020
48
Oday 40 Dalhousie Yacht Club
Where can I source SuperHatch seals?
I am starting the replacemen process on 5 SuperHatches.
Don
The SUPER hatch and parts appear to be no longer being made by Lewmar.
I checked Hatchmasters LEWMAR Super Hatch Seal - HatchMasters
They show the seal as out of stock. It shows a picture that may be helpful.
Aug 21, 2020
48
Spoke with Tony at HatchMasters. He has stock of the SuperHatch seal, $7/ft off the roll......He also stressed how HARD it is to set the seals and recommended only buying enough to TRY replacement on the smallest hatch. Apparently he has a WIZARD locked up in the back of his shop that does SuperHatch seals.
Guess I'm heading down a dark path by myself...
MitchK
Sep 22, 2017
102
Don, Tony at hatch masters is correct. The absolutley hardest part of the hatch rebuild was replacing the gasket. If your gasket is not torn, or pulled out of the frame, I would not replace it. Getting the seal correctly installed in the corner slots was very difficult. The slots in the corners is very narrow and the portion of the seal that goes I to that slot is significantly wider than the slot. I ended up using a variety of blunt edged "tools" to help work the seal into the slot. I also used copious amounts of soapy water to help the seal slide in. The rest of the rebuild was pretty easy.
Jan 7, 2011
5,973
Oday 322 East Chicago, IN
I was replacing the windows in my companionway doors recently...the old ones were Lexan I believe.
I got quotes for Lexan and plexiglass....and then we discussed tempered glass, which I think op would withstand crazing way better than the plastic options...
Does anyone use tempered glass in a hatch? Either new or as a replacement Lens?
Greg
