LEWMAR OPENING PORT SEAL REPLACEMENT
bsouza
Jun 19, 2016
1
Catalina 36 mkII Ventura CA
I have purchased new seals to replace two leaking Lewmar opening ports in my Catalina 36 MKII. My question is, does anyone know the correct procedure to access the ports? Do I start by removing the interior plastic port frame? Or do I need to remove the exterior aluminum frame?
Any tips on how to replace these seals would be appreciated.
Phil Herring
Alien
Mar 25, 1997
4,923
- - Bainbridge Island
I don't have a Lewmar port in front of me, but I don't believe you need to remove anything. The seal should pop into a channel so then lens, when closed, presses against it to form a seal. I _think you can do that with the trim ring on, but even if you have to remove it you shouldn't have to mess around with the aluminum body.
JamesG161
Feb 14, 2014
7,756
Hunter 430 Waveland, MS
The dog down O-Ring seals or the compression gasket that seals the plexiglas, or the bedding that seals the frame?
Jim...
PS: I am in progress of doing my Lewmars, one by one.
