Lewmar 40ST Winch complete disassembly
5
Catalina 30 Croton,NY
I have Lewmar 40ST two-speed winches on my 1984 C-30. Anyone know how to get the last two gears out of the winch body? Once I removed the main shaft assembly, these two stacked gears moved around but I couldn't get them out. There is a large gear over a smaller one with a pawl assembly inside. (This has to do with the high/low gear selection depending on clockwise/counter clockwise rotation.) It seems that the top gear has to be lifted so that the smaller (lower gear) can be removed first. Only then, will the larger gear move downward and be able to fit in the slot to be removed. I sprayed teflon lube in the assembly but I'm sure there has to be a way to remove them for proper cleaning and lubrication.
I tried to upload the Lewmar service manual
with pictures but the file size was too big. Try downloading the manual from the Lewmar website. The picture's from Calder's book, which i used to service my winches. Just carefully lift from below anything that won't come up. Make sure you have removed everything from the main vertical spindle.
Bob S
Sep 27, 2007
1,796
Beneteau 393 New Bedford, MA
I have a maintenance manual in pdf format. I'll try to attach it.
Dec 27, 2008
5
Thank you all for your help.........It looks like that on my pre 1984 winch I have to remove the winch from the boat to remove a plate to get to the lower gears........PIA.....so for the moment, I'll stick with some spray lube to the lower assembly.........
