A
Aldo
How many of you have rigged your C-22 to steer itself? I had done this off and on in years past, either using the boat hook, or bungie cords. This year, I took a telescopic snow brush and cut off the brush part and made a hiking stick that connects to the tiller and the winch and is easily adjustable. My boys call it the "Techno-stick". I did build some springs into it, so that it just moves back and forth a little when the boat goes through a wave. It is a great feeling to sit back and have the boat steer itself. I have seen it easily hold plus or minus 5 degrees for about 20 minutes. That's way better than I can do. It also seems faster, (probably because it stays on a straighter course). The only time I usually get help at the tiller is when it is really windy, and then I don't really want the help. I must admit that I am still learning how this works with different sails, but I am really enjoying using it and it makes for much more relaxed sails. The only bad thing that I have noticed is that it tends to steer the boat right at crab pots, and there are plenty of them in the Chesapeake Bay. Aldo
