Get Extra Material While you are at it...
And get it to match the color of your sail. I got a great tip from a well known sailmaker once. He said the best way to patch small tears in your sail is to use the heavy duty adhesive sail number material. When used on both sides of the tear, the repair will probably be stronger than the sail.I have taken his advice, and it has worked like a charm.Best Regards, Rob
