hello all . . .
Hunter 36 1980 model
Has any Hunter 36 owner of this age experienced and care to relate their chainplate failure?
My stem fitting is currently being rebuilt due to stress cracking below the toggle pin hole. (I believe some blame lies with previous / present operator error, over tightened headstay/backstay) And I plan to sleeve (ss) the bearing holes in the hull and deck as these are wallered oversize. As well as replace the aft ‘u’ bolts. No catastrophic failures . . . yet. The other six chainplates seem to be ok on a quick visual ck, but who knows at this age??
This of course goes to service life of the base material, 304 / 316ss. 35 years seems to be the time.
One poster (J. Cherubini II) stated that 304 was the material of choice due to the embrittlement factor of 316. And I am also thinking about the associated problems of welding the additional bearing washers for the toggle pin above the deck.
But, the bigger problem for stainless seems to be the danger of oxygen starvation when sealing the thru deck hole and crevice corrosion stress cracking.
This brings me (IMHO) to silicon bronze and chucking ss as the replacement material for new chainplates.
So, the question is 1) How to stop the leaks at the thru deck holes for the chainplates if I use ss? 2) Is a simple visual (dye penetrant / 4x loupe) chainplate inspection adequate, or is it time for x-ray? 3) Or is it simply time, and address the leak problem?
Thanks for the input . . .
Tom
s/v Driftwood
Oakland Estuary
Tom
s/v Driftwood
Oakland Estuary
