I purchased my boat a few years ago knowing the windlass was not working because of the solenoid. I replaced the two-directional solenoid with an automotive solenoid which only switches on in one direction. This was a temporary fix because of the expense of the two way solenoid (near $200). Now I'm ready for my windlass to work both directions. Attached is pics of the schematic and the current solenoid and wiring. Is it possible to utilize another automotive solenoid to make the engine run in reverse? If I'm reading the schematic correctly the Pos becomes Neg and the Neg becomes Pos to reverse the motor. Thoughts/suggestions would be appreciated.
