Length of stock winch handle
Feb 26, 2012
13
How long is the stock winch handle for a Hunter 26? I'm wanting to purchase a little longer handle to crank up the mast. I don't live near my boat so I can measure it.
Jul 12, 2011
1,165
Leopard 40 Jupiter, Florida
Either 8" or 10" are standard, depending on your tradeoff between speed and force. While I always advocate having an extra handle aboard, for when you throw one to Neptune, perhaps for a single purpose activity like mast raising you should consider other mechanical advantages. Consider replacing your single line with a doubled line and block at the mast to make it half as hard (but twice as long). Solving these little problems by using different lines is the essence of sailing.
Feb 26, 2012
13
I'm using factory provided winch handle so I suspect it's 8". I was looking for a longer handle to raise mast and I did really want to double length of line.
Feb 26, 2012
13
And that 1st post should of read "I can measure it" as I sail the boat on the great lakes in the summer but live in Arizona.
7,606
Alden 50 Sarasota, Florida
I assume you know you can easily calculate how much (read - how little) mechanical advantage that extra 2" gets you over an 8" handle??
Bigger winch time...
Jul 12, 2011
1,165
Uh ... 25% more? I don't think I've ever used an 8" handle, but I'm a weak office worker, not a real brawny sailor-man. :cool:
Joe
Jun 1, 2004
8,269
It's always advisable to have a couple winch handles of each size 8" and 10" I prefer the palm grip type. If your winches feel underpowered, then moving up to a 10" handle will help a lot. If you still have trouble, it might be time to upgrade to larger winches.
When I added a dodger to my boat, and upgraded its winches. My new fave handle is the Lewmar one-touch palm grip. A lot easier on the shoulder.
Likes: Ward H
RoyS
Jun 3, 2012
1,742
Make certain you have clearance for a longer handle to swing.
Jul 12, 2011
1,165
I think the OP's original question was that he could not measure anything as he is more than 1,000 miles from boat. That said, most larger waste marines carry a selection of winch handles, and Amazon will have one on your doorstep in a couple days, both returnable. Perhaps the best advice is to wait and buy when you arrive at the boat. It's not like you're going to use it in Arizona.:beer:
Aug 12, 2018
163
Hunter 26 Carter Lake, Colorado
Are you raising the mast right? The H26 system is designed to not need a winch, let alone a bigger winch/longer winch handle.
It’s not for everybody and it’s not speedy, but I haven’t felt the need for a winch.
Jul 12, 2011
1,165
Actually, it’s closer to 5% more. But perception is everything:)
Don't think so. Mechanical advantage is the ratio of the distance from the fulcrum for a lever. 10"/8" = 1.25 = 25% increase in mechanical advantage. (Lever - Wikipedia) In the immortal words of that famous Greek sailor, Archimedes "Give me a place to stand and with a lever I raise my mast" (This has been misquoted in other places):cool:
Feb 26, 2012
13
Well thank you all for the input. I'm thinking longer handle will do the trick. The stock winch works but it would be nice to use a less effort and I think that may translate in to more control when raising the mast.
Feb 26, 2012
13
Well how do you raise the mast? The manual uses the winch.
