Length of running rigging on 86 H31
Aug 16, 2009
1,000
Hunter 1986 H31 California Yacht Marina, Chula Vista, CA
I am replacing all the running rigging on my 1986 H31. I could remove the old lines and sheets and measure, but I'd rather get the dimensions and have the new lines in hand before I bare the hardware. Some of the diameters I've chosen are pretty liberal for this boat and may need to be modified if folks think they will bind in the sheaves or clutches.
1. Halyards: 106' X 7/16"
2. Jib sheets: 50' X 1/2"
3. Furling Line: 62' X 5/16" [first 20' cored]
4. Traveler: ?
5. Soft Boom Vang: ? X 7/16"
6: Mainsheet: ? X 7/16"
7. Jib sock: ?
Mar 20, 2011
623
Hunter 31_83-87 New Orleans
Check the SBO site for most of the recommended lengths and diameters for halyards and jib sheets. Furling line length on mine is 66’ and dia is what I have. I’d rather err on the side of more for wraps around drum.
You Also need to take into consideration if these lines run to the cockpit for overall length. As far as the rest of the lengths and diameters, what do u currently have and do they bind? What does ur main sheet look like? No all H31s are rigged the same.
Beneteau 323 Annapolis MD
4. Traveler: ?
7. Jib sock: ?
The biggest lines on my B323 are 3/8., 8 mm.
Aug 16, 2009
1,000
That's interesting, Ron. While I agree that the loads imposed by our sails are unlikely to ever part a 3/8" line, when it comes to jib sheets I much prefer working with a larger diameter line. The issue in my mind was whether 1/2" would crowd the winch drum and fit in the self-tailor.
Jerry, I added additional turning blocks and clutches so I could run almost everything back to the cockpit.
Nov 26, 2014
51
HUNTER h31 Northport L.I.
Wufibugs, I have an 87 model with maxwell 20 winch for main halyard and 7\16 fits fine no issues 3\8 line for main sheet ,and 1\2 line for 135 genoa on maxwell 23 winch no binding on any sheeves or self tailer on drum plenty of room good luck. Eddie
HMT2
Mar 20, 2014
900
Hunter 31 828 Shoreacres, TX
4. Traveler: ?
7. Jib sock: ?
Literally did 5 & 6 yesterday
Boom Vang 38 feet of 3/8” with an eye splice leads back to cockpit
Main sheet 55 feet of 1/2” with an eye splice 1/2” for the hand
I replaced the halyards and furling line a few years back, let me look through my records and see if I have the lengths. I used 3/8” on all of those, but agree with the 1/2” inch on the jib sheets. I think there is a formula out there for the furling line. To Jerry’s point about oats being rigged differently it’s not difficult to measure for the main sheet, boom bang and outhaul.
