LENGTH OF HOSE NEEDED FOR 322
2
We have ODOR in our boat-need to replace with ODORSAFE HOSE...but at 8.50 + a foot I dont want to buy too much or get too little. ANYone know how much it takes? Could not find it in the manual.! thanks!
Jun 7, 2004
8
- - Boothbay, Maine
Odersafe Hose
HI,Louanne,My first step would be to remove the hose you have now. and measure how long it is, and replace it. The way you decribe it it sounds sinple. Doses it goes from the holding tank to the vent,? or to the pump out deck out fitting or to the thruhull fitting. all these questions are needed. Good Luck Frederick Pierce.
Jun 4, 2004
1
- - Oriental, NC
Been there, Done that
I replaced the hoses on my 322 last season. I have a LectraSan in addition to holding tank, so I probably needed a little more hose than you will. I do not suggest removing all your hoses first, since it is easiest if you attach the new hose to the old hose with a coulpling and use it to pull the new hose in through the same route. This may not be the same for other boats, but I think that on the 322 it would be very difficult to install new hoses without using this method. I used a flexible tape measure to measure the individual pieces while still in the boat and added it all up - about 25 feet or so for me. You will probably need about 20 feet.
