Legend 40.5 ZSpars furling mast
fero
Jan 15, 2010
133
Hunter Legend 40.5 Victoria
Hello again,
My 1995 (model 1996) 40.5 has in mast furling main. I would have a few questions for owners of sister ships with same arrangement. My boat manual has a short U.S.Spars generic manual added but the rig plan with dimensions appears to be for non furling mast. Here are my questions:
- After how many seasons did you have to get a new main?
- Do you have main dimensions and cloth weight you could share?
- Did you have to change the main furling line, how did it go? Any problem with backing plates (could they drop into mast?)
- Do you know if the genoa (jib) on non furling mast rig fits the furling mast rig?
I have spoken to U.S.Spars they were going to check if they have mast drawing, no idea if or when I may get something.
As always many thanks for your input.
Too bad there aren't responses to your questions. This post will bring it to the top of the replies and maybe more eyeballs will see it. You ask specific questions about a specific boat. It's hit or miss for the right person to see it.
fero
Jan 15, 2010
133
Thanks for noting.
There are several sister ship owners who are frequent contributors, it seams however that they don’t have furling main. It looks more of a miss than hit for now.
Not on a Legend, but we do have a US Spars furling mast on our Beneteau. We replaced the main after 11 seasons. It was a little blown out but didn’t give us any big problems furling. It was just a little more temperamental about not unfurling when the sail could fill. We are still on the original furling line after 12 seasons. we remove the main every winter. In 12 seasons of doing that I’ve only dropped one Allen wrench down the mast. :banghead: I’d recommend putting a rag in the mast before removing the shackles when trying to remove them, to catch anything loose. I assume the jib is the same with either mast, but I’m not sure about that.
  1. - After how many seasons did you have to get a new main?
  2. - Do you have main dimensions and cloth weight you could share?
  3. - Did you have to change the main furling line, how did it go? Any problem with backing plates (could they drop into mast?)
  4. - Do you know if the genoa (jib) on non furling mast rig fits the furling mast rig?
Sorry to see that no one could provide specific answers to your queries. I do not have your specific boat, nor do I have a furling mast.
From my sailing experience, I would respond thus.
1. The number of seasons you get from a sail is not dependent on the mast or the specific boat. It is about how and where you sail. The conditions under which you sail, how you care for the sails, and the sail materials used in making the sail. If you're racing the Swiftsure every year off Vancouver Island, or leave your sails exposed to the Caribbean sun and Trades, you may only get 3-5 good years before you start to experience degradation that will require frequent loft visits.
2. Sail dimensions are best found by measuring your rig. It is like buying a suit. Do you want the first coat off the rack of a discount clothing store or one tailored to your boat with all its specific requirements? The cloth weight would again be dependent on the type of sailing you expect to do, the sailmaker you choose, and the materials available.
  • Coastal bays (protected waters, shorter trips, lighter/variable winds): 7–8.5 oz/yd² (e.g., Challenge cloth). It will give you good light-air performance and easier handling. It will support your daysailing or coastal hopping, where you can reef early.
  • Open ocean cruising (bluewater passages, heavy weather, long exposure): 9--10+ oz/yd² (e.g. Contender Supercruise or Fastnet). Open ocean cruising requires a heavier built-in margin for storms, prolonged UV/salt, and chafe. Contender and others often spec ~9 oz mains and 8–9 oz headsails for 40ft offshore use. Some bluewater sailors go 9.5–10 oz or use “bulletproof” grades like Rolly Tasker Fastnet.
3. No answer
4. Again, it is your rig that will determine the size of a jib/genoa. Your style of sailing might suggest two fore sails. One a 90-95% jib for heavy weather sailing and a 135-155% Genoa for those long light wind reaches, perhaps in the trades. I would find a good loft that will work with you. There are several in Victoria, Canada, or I know a good loft and manager in Anacortes, Washington.
Good luck and fair winds..
fero
Jan 15, 2010
133
Thanks for good comments, here are some thoughts after 7 seasons in Caribbean with furling main. My 3 previous boats had std main sails with lazy bags which would be my preference in retrospect.
I still believe that there are some specifics affecting life of furling main sail..
The transition from the sun protected end triangle (which has 3 layers) to rest of sail seams to me more stressed, the rolling of the sail around small diameter furling foil is not always perfect, not everybody drops the sail when boat is stored. The usspare manual says 7 or 8 seasons may require replacement. I also wonder if there is a good way to prevent furling foil from banging when sail is down. Cloth weight being directly related to it’s thickness affects ease of furling as available space gets filled up.
Feb 10, 2004
4,256
Hunter 40.5 Warwick, RI
Hello again,
@fero From my archives - Z-Spar pre-2000 catalog with drawings. Maybe this will help you.
Personally I would not go back from furling unless I were getting a higher performance no-compromises boat. 7 Caribbean seasons might be as much UV load as 10+ seasons where I sail so I guess that could change the math.
That is not a place we’ve had any trouble, and I don’t think I’ve read many reports of issues there. Usually what I’ve seen, and the problems we’ve had when we’re not careful, are higher up on the leech when the sail is maybe 3/4 furled.
I usually tie a downhaul to the swivel, and use the halyard to pull it about half way up. That dampens the noise maybe 50%; enough to make it tolerable for the few hours I’m on the boat in the late fall and early spring without the sail. Once the boat is on the hard it doesn’t move, so no more noise anyway. I’ve heard of pool noodle tricks to reduce the noise better; I haven’t tried those myself.
fero
Jan 15, 2010
133
Hello again,
In process of getting new furling main and Genoa. Once on the boat in a few weeks I will have to take bunch of measurements. I wonder if a furling and standard non furling masts have the same basic (I J P E) dimensions.
I have asked the same question to US Spars, they did advise that they cannot find a drawing in archives.
Would love to hear from another 40.5 owner with furling mast, guessing mine is not the only one with furling.
Regards
Frank
