Legend 37.5 Water Tank Replacement
8
Hunter 37.5 Cheboygan MI
Has anyone replaced the water tank on a Legend 37.5? If yes, where was the replacement tank purchased? Was replacement tank the same size as original? What needed to be done to remove the original tank - will it fit through bulk heads and companion way or did you need to cut it up to remove it? HOw did you fit the replacement tank through bulk heads?
