Installed new led (red,green,blue) rgb strip lighting with multi functional remote in cabin and cockpit. I wanted to give more ambiance low voltage light in the cabin and cockpit. This upgrade was fairly easy to do after I came up with my game plan.
Strip lighting is very easy to install. Led strip light has markings approximately every 2-4 inches where it can be cut to size and wired to the power transformer that comes with the kit. Cut strips to length and pealed off self stick adhesive and stuck the strip to the fiberglass head liner just along the area where the jib traveler track is bolted thu the deck. Wired power transformer from 12 volt directional cabin light that is attached to fiberglass deck stringer. Repeated this on both sides of main cabin. I did the same in the v-berth and aft quarter berth along the head liner using a 12 volt cabin light as the transformer power supply. The new led strip lighting amazingly draw about the same power as one of the two bulb cabin lights.
The new lighting worked out great! The multifunction remote allows you to choose approximately 20-30 colors and light intensity.
Installed the led strips under all the lazarettes in cockpit as accent light. I like to use the red color function while out sailing because it's easer on you eyes.
This was a great project for approximately $40.00 per kit on Amazon, total project cost was approximately $120.00. I was truly amazed how much light you get from led lights vs a standard 12 volt bulb. Also was amazed by how little voltage led uses, roughly 75% less.
