LED running lights for a dinghy
BobM
Jun 10, 2004
3,269
S2 9.2A Winthrop, MA
I have been thinking about trying to make up a set of battery powered running lights for my dinghy, a 9.4 water tender. In the fall I am often out at night, returning in the dark and must return by tender through the mooring field in the dark. I usually run a small lantern, but have thought about rigging a battery powered set of LED running lights. Has anyone done something like this?
Thanks,
BobM
7,743
Alden 50 Sarasota, Florida
Hi Bob
I assume you know that Aqua Signal, among others, makes some portable running lights which can be mounted on a dinghy with either suction cups or affixed to a permanent mount, all of which can be run off standard AA batteries. Just be careful you kids don't drop them overboard.....
Oct 22, 2008
3,502
- Telstar 28 Buzzards Bay
IMHO, you really shouldn't trust the suction cup mounts...they're likely to dump the nav lights overboard just when you need them most.
BobM
Jun 10, 2004
3,269
I know about those lights, but I don't think they would mount effectively on my water tender. It has a rough surface unlikely to accept a suction cup and no place I can the clamps would work on. Last time I looked at them they weren't LED's, as I recall. I throw my dinghy around a lot, so I don't want anything permanent that isn't low profile.
Here's a bright idea (pun intended). I think I will just epoxy a flat piece of plastic stock to the rough surface on the bow. Then I can use the suction cup mount. Problem solved! The Aqua Signal is buoyant so if you drop it in the drink you can just go get it. However, it is expensive compared to those on Defender. Plus, I'd rather get a pole mount stern light as having the illumination up high not only makes you more visible, but it will light the general area a bit, as well.
Joe
Jun 1, 2004
8,348
I'd think a couple of eye straps mounted to the transom, one above the other, would be more than adequate to allow a veritical pole mount for your light. The pole could be modified to hold the light....
Now.... that said... I think you are making this problem too complex. For $18 you can buy the defender unit and experiment with where it works best. If you're worried about it falling over board, tie a lanyard to it and harness it to the boat in case it becomes dislodged from the mounting area. I don't see why you can't fasten a small "L" shaped bracket in the bow to mount the clamp version of the light.
Catalina 320 Dana Point
I had the rubber mounts come off several times, last time I re-glued using a gel form of super glue and they have remained attached for quite a while now, knock on wood. Still don't trust them entirely, dink is also stored out of the sunlight and weather most of the time.
caguy
Sep 22, 2006
4,004
I use an led headlight. It sits up high enough and shines where I look. Might be cool to add green and red lights to the side straps.
My wife calls it my geek light.
Frank
Oct 22, 2008
3,502
Of course, you're not USCG legal in most places using a LED headlight. Also, if you're not facing forward you could cause some serious confusion, especially after you added the sidelights. :)
Frank
caguy
Sep 22, 2006
4,004
I was only kidding about the side lights, I'm not that big of a geek. Most dinks that I have observed in Avalon have no lights at all. At best most carry flashlights.
Frank
