LED cabin lights.
34
-Beneteau -361 -San Pedro
Has anyone replaced the existing halogen reading lights in the cabin of a B361 with LED lights? Halogen lights get so hot, am thinking of replacing with cooler LED's.
sailrj
Jun 16, 2004
43
Beneteau 351 0 Aurora, KY
Just replaced all the G4 lights in an Oceanis 351 with cool white 24 LED G4's and they are great and use about 10% of the power of the regular G4's. I bought the cheap G4's off eBay and ordered twice what I needed. Half were bad, but they have been replaced- got a few extras. Definitely order the cool white- tried a couple of the warm white's and they have a yellow cast.
Apr 27, 2010
970
Beneteau 352 Hull #276 Ontario
@sailj
what vender on ebay and what style of g4's did you get for your Bene????
Nov 23, 2009
437
Beneteau Oceanis 361 Clipper --
I have also replaced all halogens with cheap "LED G4 replacement bulbs" from ebay (I don't remember the seller but there are many and seem to sell the same things). I have bought the soft white ones because I don't like the cool white. Of course this is a personal taste. Colour wise they don't seem that good because the colour of some are yellow-white (as expected) but some others have a bluish color! But who cares, there were so cheap....Consumption wise, they are EXCELLENT. How long they will last? I don't know yet. I just bought them a couple of months ago.
Just make sure you buy the ones with the site pin.
Apr 27, 2010
970
I just see that there are so many different G4 types. There are the one sided, flat type with various numbers of led's. There are those that are rectangular with leds on top and all the way around. Which ones did you go with??
Beneteau 323 Annapolis MD
http://cruisingsolutions.com/ are the folks who usually have a booth at the boat shows. The Beneteau ceiling fixtures will most likely use the round wafer type with the G4 leads coming off to the side. You might have to trim the leads to get the wafer within the confines of the fixture.
Gunni
Mar 16, 2010
5,937
I replaced all interior G4 lamps with current-limiting LED's. All LEDs are not created equal and some of them should not be aboard. Problem with many of the cheap LED's is that they are resistor controlled. You know how a resistor controls fluctuating system charge right? Here is a demo:
http://www.youtube.com/watch?v=QdiAUovJ17w&feature=player_embedded
Cheap resistor controlled LED's would be a good fit for low-voltage residential lighting - where the voltage is consistent.
Feb 6, 1998
11,724
Apr 27, 2010
970
Interesting and definitely a hazzard if you're running the motor or charger while using the lights.
I ordered a couple of these http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=390297223173 just to see what they are like.
I did notice that there appears to be a voltage regulator IC on the PCB as shown in the photos..
Some of the other suppliers LED lights did not have this chip.
I'll only know if I'm right when I get them. I'll report back.
Oct 2, 2008
34
Did you replace the housing units for the reading lamps? If so, where did you get them?
Gunni
Mar 16, 2010
5,937
Yes, there are 8 of them on that chip, they are called resistors. They get very hot when your house voltage exceeds the manufacturer's assumed house voltage. Short of that voltage they're just dim.
Apr 27, 2010
970
Yes there are 8 SMD resistors, 181 ohms each and there is also an IC chip which may be the volatage regulator which maintains a constant voltage. won't know until they are in my hands.:naughty:
437
Reading lamps? I guess you mean the 6 reading lamps in the cabins (or 4 depending how many cabins you have). No I haven't change anything there. To be honest I cannot even understand what sort of lights these are and if there are any LED replacements.
By the way the lamp I use most of the time is the one above the galley (10W fluorence?), which again I cannot find any sort of LED replacement. Any ideas?
I noticed at the Annapolis boat show in October that the newer Beneteau models (34, for one) had the same light fixtures as mine, but instead of bulbs they had LEDs. Maybe those fixtures are on the Syselios parts site? This includes the pivoting light in the head. It would be nice to just get those strips of light to replace the G4s.
Mike B
Apr 15, 2007
1,013
Beneteau 43 Baltimore, MD
Yes Syselios has them. Look under Common Parts rather than a specific model. Looks like the G4 LED with the side pins are $41.97 each. Not sure if they're the bright white or warmer look bulbs.
Apr 27, 2010
970
The previous link above shows a fluorescent replacement. Don't know if it works, but looks interesting.
http://cruisingsolutions.com/category/shop/lighting/cabin-lighting/page/2/
