LED Conversion
You have a good idea to replace the incandescent lamp with LEDs. In a 12 volt system, you will probably want to gang 5 LEDs per resistor max. There are several resistor calculators on the web, search LED resistor on google and you will find all the info you need. On Ebay, I like the seller ColdfusionX for LED suuplies. I am doing some of my interior with superbright red LEDs and mounts from his website. He also sells a digital voltmeter for less than $10 that will be a part of my electrical system upgrades (sensitive to a hundreth volt to see the effect of my solar panel). I saw a website once wherein the author had made a ring of LEDs and epoxyied them in place to replace a lamp but I don't know where that is now. Good Luck John S
