I thought it made great sense to replace my battery-depleting 10-watt anchor light with an LED bulb, and with some help from the forum found what seemed to be the right bulb for the Aqua Signal 25 fixture. I ran up the mast, broke the fixture trying to open it, and then ran a new one up and wired it and mounted it, to find that the LED bulb (which you should know is polarized or something; only works in one direction) only worked in half its diameter, so gave good bright light for a 180 rather than a full circle. I had bought two of the bulbs ($16 each at batteries plus) and they both did this. I grudgingly installed the incandescent that came with fixture. Maybe a whole new fixture?
