Purasan vs. Electro Scan
The PuraSan
Raritan Purasan can be an excellent choice for boats in fresh or brackish water and toilets that use onboard pressurized flush water...that what it was designed for.
The advantage: It costs less and draws less amperage than the Lectra/San or ElectroScan because it uses supplied chemical from a cartridge instead of electrodes in salt water.
The disadvantage: the solid bock of chemical (halon) in the cartridge lasts about 800 flushes--about a season in most places, maybe 2 seasons where the sailing season is short--requiring replacement of the entire cartridge at a cost of about $100 including shipping. Because it's rated HAZMAT, which adds a whopping shiipping surchage, few if any boat supply retailers carry it...so it has to be ordered directly from Raritan. And you cannot use anything else instead.
You'll prob'ly want to read the manual for both devices to determine which is the best choice for your boat.
John...how far apart are the heads on your boat? Specs for the LectraSan, ElectroScan and PuraSan all require that the treatment tank be within 6' of the toilet...'cuz that's as far as most toilets can move bowl contents in the amount of time anyone will spend flushing one...and bowl contents have to get TO the device to be treated. So connecting two toilets to the same device should only be done if it can be located within 6' of both of 'em.
