Leaky Windows
L
Larry
I have a 1982, 30 Catalina and my windows leak. I want to re-seal the windows. I am looking for any ideas or suggestions. It looks like they are leaking in the aluminum framework around the windows where the glass is sealed by the rubber. Should I take them to a glass shop and have them re-done? What do I use to seal when I re-install to the fibre glass? Thanks Larry
C
Chris Gonzales
Check the ARCHIVES
Larry, Lots has been written already. Check the archives first and you will find what you need.
H
harvey
Catalina direct has what you need to fix the leaking windows.I had the same problem.
