Leaky windows.
Jul 8, 2019
2
Hunter 33 Port Chester
The windows on the port side in the galley leak whenever it rains. I used sealant last year and it worked for the remainder of the season but its leaking again. Any remedies?
Feb 21, 2013
4,638
Hunter 46 Point Richmond, CA
Is it the frame or gasket that is leaking? You might find the sailboatowners forum thread of interest and Yachtsurvey article on "How to Repair Window Leaks".
Jan 5, 2017
151
Hunter 356 SF Bay / Delta
How did you use the sealant? Did you remove the portlights, clean all the existing sealant, then re-apply and re-install portlight? Which sealant did you use?
