Leaky port , hatch , ck o rings
19
Catalina 30mkIII austin
just felt the need to post this, I had three ports that leaked bad.after reading about 15 posts on several boards,most said replace seals,some said that was a wast of time just put in new ones. none said ck the O rings in the latches.
2$ later my ports are tight as a drum ,not one drop. you need to greese them
every so often they just wear flat atfer a while. maby i got lucky but if your drippin, this is the first thing to ck.
hope that helps
