Leaky inflatable
IanJ
Nov 7, 2008
152
Hunter 31 Port Royal, CA
I have an Avon Rover 23-10 dinghy. It is 100 years old, and is a brilliant inflatable. Only problem is it has a slow leak, ( I suppose they all do) and has to be topped up every day, though not badly. I am presuming it is leaking from one of the seams. Anyone ever treat the seams, or is this just one of lifes problems you deal with?
Nov 6, 2009
353
Hunter 37 FL
Took ours to West Marine store and they fixed it. Not sure if all stores do that.
Apr 12, 2010
12
Ericson 35-3 Annapolis
I had the same problem with a used Apex Hypalon dinghy I bought. I used a latex fluid adhesive you can get at WM. You pour it into the valves and then turn the dinghy a few times so it spreads internally through the chambers. Worked great! I used to have to top off air every day. Since I used this stuff in March, I haven't had to inflate it again a single time. A bottle of this adhesive is about $60. Good luck.
IanJ
Nov 7, 2008
152
Sounds like the West Marine we know and love! Thanks for all the advice guys, actually sounds very promising.
Feb 17, 2004
268
Hunter 30_74-83 Lower Salford, PA / Tolchester,MD marina
Spray the dink with soapy water and watch for bubbles. Your leak may not be the seams but at the valves (which are not that difficult to replace)
Mar 26, 2011
3,979
Corsair F-24 MK I Deale, MD
Exactly.
Also, if the valve is leaking because it is a bit older, a little bit of glycerine on the cap seals and check valve may do the trick; it takes months to dry out and this trick worked for me. I did this in September to confirm that was the problem, and it's still doing pretty well (pump every 4 weeks to firm it up).
IanJ
Nov 7, 2008
152
I have to say that the effect is amazing. I bought the $60 bottle from West Marine, poured it in, shook it around, and I have a whole new dink! Thanks guys. This is like Viagra for dinghys!
IanJ
Nov 7, 2008
152
One more thing. Is the Avon Rover 23-10 PVC or Hypalon? I cannot seem to get a straight answer. Anyone know where I can get new seam tape material too, to replace some pealing tape?
