More possible leak sources
Also....1) check the port/window in the cockpit. If it leaks, it can get in between the cockpit floor and inner liner.2) check inside the port side rope locker lazarette. When it rains hard or you wash your boat, water can get in there. Any holes or uncaulked screw holes will allow water in.3) Be sure to get that leak!! Water got into that area on my boat, and froze during the winter, causing cockpit floor damage.
