My freshly and carefully mounted port chainplate leaked like a sieve with the rain. I took it apart and the forward surface of the chainplate was too close to the rectangular opening to allow any caulk in. I believe that it would help to bevel the top of that opening in much the same fashion as we do round holes for bolts. I will post the results.
As i was disassembleing said chainplate, I was disappointed in how easily the 3m 4200 caulk came off the surface of the chainplate, as well as the deck (which is painted in that area). The surfaces were carefully cleaned a prepped with acetone. I even sanded the deck a little to increase adhesion. When I removed the caulk from the deck some of the paint came up with it. I have not had the adhesion problems in areas where caulk was applied to gelcoat.
Which brings up another conclusion: Paint on a boat is a bad idea. Folks who have followed my post know how much trouble i had with paint adhesion to my repaired deck areas (with epoxy). Some areas were done three times. I consulted factory, net, etc. I am a stickler for details (although i did screw up the first time by not thinning the primer properly to specs). All I can say is I have have been dissapointed with the results and propeties of paint EVERYTIME, and have been impressed with the durability of my gelocoat, which takes a hell of alot of abuse EVERYTIME.
As for old gelcoat being in need of paint...see mainesail's "buff magic" thread.
Anyway, just my worthless opinion.
Keith
Keith
