Leaky 1978 27 hunter
4
-Hunter 1978 H27 North East, MD
removehtml]Greetings. I have a lovely 27 but its getting really wet inside. I have leaks coming from many areas but the ones i hope to fix soon are coming from the wooden rails on the top deck of the boat. They aren't thru bolted and i believe water is seeping through all the spots where wood meets deck. I did some exploring and when i chisled through the wood to get to the screw heads I found the 2 out of the 3 screws i tried were stripped. So, i got frustrated and quit. I'm really not trying to replace the woodwork cause funds are low but what options are out there? Any advice? Also, i have the black metal toe rail that goes all around the boat. What a pity cause this has its leaky spots too. I've tightened up some of them but with no real success. Any advice on making this a bit more water tight? Thanks, Bring on Spring! Error: Error: expected [/URL], but found [/removehtml] instead[/removehtml]
Jan 22, 2003
744
Hunter 25_73-83 Burlington NJ
Deck leaks, etc
I am familar with these hassles-- have done some of them myself. Contact me directly if you'd like me to look at it. I am 2 hours from you. cherubiniand@aol.com
