Leaks
Joe M
Just bought a Capri 25 and am finding water in different areas of the cabin after a good rain. I have not traced down the source of the leaks. Is the Capri noted for this? and if so what is the usual cause. Thanks Joe M.
L
Lowell Irwin
I had a Capri 26 that leaked every time it rained, especially in the galley area. I traced the leaks to the stanchions. Check to see if they are bent. If not simply rebed. If they are bent replace them. The stanchions at the lifeline gate receive a lot of tugging from getting on and off the boat and eventually start leaking. Hope this helps!
