Pesky Leaks
Richard,If you have a deck stepped mast, the step might need to be rebedded, there are also electrical connectors that go through the deck. Any place there is an opening cut, you have a possible leak, and it can run several feet from the original enterance to the point where you see it inside your boat. Depending on the year of your vessel, it might be a good time to start at the bow and rebed "everything" in sight, but give yourself plenty of time, at least a couple of days.
Ben AllenMontgomery, AL"Latte Dah"O'Day 26
