On both sides, at around the fourth port hole, quite a bit of water comes in, and I looked one day and suspect that the culprit are the toe rail bolts in that area
My question:
Can I use, temporarily, a clear latex acrylic silicone to at least remedy the situation?
I know what I should eventually do: summon some help, remove the bolts and insert 4200 into the hole and then tighten
Since I am in the business of doors, I glaze the glass using the same product, which hardens but creates at least a seal and no water should come in.
I will do what is right, but for now... or should I use something else?
Thanks for helping
My question:
Thanks for helping
