Leaks
5
hunter 1988 33.5 ladysmith
I have a leak in aft cabin,seems like it is comming from deck to hull joint.Any tips to resealing joint.
Dec 2, 1999
15,184
Les:
Have you considered just torquing down the bolts on the toe rail? I think most of the older boats had a butyl caulk that was applied to the joint before the deck was put into place. It stay pliable for ever.
Jun 4, 2004
255
Hunter 376 Annapolis MD
I suggest that you use one of the methods in the archives to determine where it is actually coming from. I've seen people waste a lot of time and do some damage acting on assumptions about leaks.
Allan
Rick D
Jun 14, 2008
7,187
I developed a small lead at the bow. Most noticeable when pounding into a head sea. I did as Steve suggests, and found some of the hull / deck /rail carriage bolts were pretty loose. Tightened everything up from bow to stern on each side, problem solved. However, if yours is into the aft cabin when at rest, it may be something else. Still, tightening the deck bolts is a good idea.
Nov 22, 2010
4
Hunter 33.5 Oostende
I had a problem like that. And I had to change the teak and that solved that problem. Unfortunaly I have another leak somewhere that causes water in the kitchen and the cabinets above as I wrote a few weeks ago.
Jan 11, 2004
65
Hunter 31_83-87 Middle River, MD
One of our annual spring commissioning jobs is tightening all the toe rail bolts. This has eliminated hull-deck joint leaks on our '86 H31.
Nov 15, 2010
13
Hunter 33.5 Ladysmith
Hi
We purchased the boat a couple of months ago and have a similar leak.It appears as if the water is coming from under the fridge area.I will be tearing the bulkhead out on the fwd side of the fridge soon.
Have you had any luck with yours?
