Leaks- updated
mary
Has anyone else experienced a leak in the aft area of their Hunter, we are brand new owners, and have salt water coming in through the aft cabin and lav. The water originally coming in where the shell and the floor meet in the lav, it streams down past the head to the floor drain. When we heel port side the water then runs across the aft cabin deck where the mattresses would be and down into the floor. We have a 2001 Hunter 290.
Don
Mary - what's the year/model?
You can get a lot of good advice here, but you will need to give as many specifics as possible for it to be meaningful. I suggest that you view your original post and click on "edit this post" and give us more info
David Foster
Cockpit drain hoses
are the first place to look on my boat. David Lady Lillie '77 h27
G
Guest
Horn to Hunter
I would get on the horn to Hunter and my dealer. There is no reason on a 2001 boat you should be having any issues of this type. Kevin
