Jorge Cela
I have a 1995 29.5 Hunter and it has developed two leaks.One is around the outter flange of the last port hole on the port side. The water drips into the cabin from the bottom of inner flange. The seals of the port are all new and no water is coming through the seals. Does anyone can tell me how to go about taking care of this problem. Does the outside flange come loose by removing the screws from the inside? What is the best way to remove the outside flange without damaging the outside surface of the cabin and what is the best material to use to seal the flange back?The newer leak is by the aft berth, on the port side. the water seem to be coming from a leak between the upper deck and the rubber bumper going around the whole boat. The caulk between the rubber bumper and the side of the boat, seem to have separated and a fine line of water is getting inside, right underneath by where the molded drainage of the upper deck is, closest to the stern of the boat. Any suggestion about the best material to use? any special marine caulk? or any silicone based caulk will do? Does the old caulk must be removed all around the boat, in its entirity? or it can be done just locally where the leak is?I thank all of you in advance for the advise.I love my boat, and I just wish, Hunter would insist that its dealers be better manned to service old boats and not just be interested in selling new boats.Best Regards,Jorge
