Window leaks
There's actually three pieces to the leaking window problem. (1) There is a green channel gasket that the glass sits in, and (2) the gray window gasket that goes around the window on the inside between the window and the frame and (3)a special sealant for the outside between the cabin side and the frame. Chances are if you haven't replaced all three , your windows will still leak. Make sure your seam where the gasket ends come together are at the top of the window. Good luck!
