I am assuming a Yanmar engine ??
Typically, the transmission(clutch) has to slide aft about 3-4" to disengage the transmission input shaft from the flywheel mounted dampener. On many boats, that can be done by removing the control cable, unbolting the coupling, and loosening the motor mounts then raising the aft end of the transmission (sling under aft of engine block) to clear the coupling. It would be best to loosen (about one turn) the bolts connecting the flywheel cover to the flywheel housing before picking up the aft end. The transmission is mounted to the flywheel cover. The transmission weighs around 50 pounds.
