One of my stanchions has a leak. I pulled it off and found it was bedded with sillycone by PO. I have a few questions on my thoughts of repair. The stanchion was mounted on a 3"x3" stainless plate, this is in addition to the stanchion base, maybe 2 1/2" x 1 1/2". So my plan is to cut the top layer of the deck just smaller then this plate clean out as much deck core as I can in this almost 3x3 hole. I then want to fill this with thickened epoxy and install stanchion with butyl bedding.
So some questions. IS that to big of a hole to just fill with epoxy? What will remove the sillycone for sure? Since this repair will be covered by the 3x3 plate does it need to be topped, as in gel-coat or paint? Thanks Greg
