H35 Skylites
Fred and All,"Reset" my H35 skylites last spring and have what I consider a good, no leak "set".Used the Dow Corning 739RTV plastic adhesive sealant (comes in a green tube) and it works great with out the screws. I don't think Dow Chemical makes a 739 sealant. Do not use DC795 silicone building sealant. DC795 was a past (circa 1999) recommendation of the Hunter factory - they have since switched to DC739 as it is a much better adhesive (sealant) for sail boat needs. To my way of thinking the screws are a no no.The secret gentlemen to a good set is to use the Dow Corning solvent OS2. This is a special blend (spray can) for lexan and and really works great in the preparation of plastic, gelcoat and metal surfaces to receive the DC739 sealant. I would not attmept a reseat again without the OS2 to prepare and clean up the area before DC739 adhesive is applied. I have no problem in saying that the task should not even be attempted without OS2 solvent. It is a must, a must. OS2 is an "enabler". It prepares the surface(s) so the DC739 will "stick" adhere to the surface(s). Also, think of the sealant application as forming a big rubber band around the edges of the lexan lens as it sits in the molded opening. I did not use any sealant on the 2" wide lip that forms the base of the opening. This is an overkill and in actual practice defeats the effectiveness of the "rubber band" concept. I did not apply any sealant to the opening before I positioned the lens in the opening. I made sure the lense set down cleanly on the lip. I have use both black and white DC739 sealant. I did not use any masking tape as it was easy to trim the sealant and to clean up the edges with the OS2 solvent.I made sure the lens was center in the openting with spacers along the sides and ends to keep the it centered as the sealant is applied. Without spacers the sealant will cause the lens to "move around" as the DC739 compound flows into the "crack" ie. the gap betgween the edge of the lexan lens and the moulded opening. I removed the spacers after all of the "cracks" were filled. The spacers came out without any trouble and I just added more sealant as needed to fll their void. After a few hours I used clean water and my finger tip to smooth and form the top surface of the sealant in the crack. I "over applied" DC739 as it is easy to trim after it has set up.In any case, do not use screws unless you want to buy another set of lens. As I recall I did use a big bag of rocks (anchor chain - tool bag, etc.) on each of the lens to hold them in place over nite as the sealant set up.I also used DC739 and OS2 to reset (three times) the lens im my Bomar hatches - (big footed deck crew) {;<}. Again, the must use OS2 was the prime element in the preparation and cleanup in makeing the task a good water tight "set".Seal on - with OS2 and DC739.RD
