H
Hayden Watson
I recently noticed that I have water leaking into by ’88 C30 at the prop strut bolts. Has anyone removed the strut to reseal it? I have removed the fuel tank and it appears to be bolted from the outside to a recess in the hull. I removed the nuts and resealed them with polysulfide, which seams to be working. My concern is that without doing the repair from the outside of the hull that it will just start leaking again. The tank has to be removed to get access so I don’t want to do it again until I repaint the bottom.
