I am about to glass over the whole mess! We have been fighting leaks around the ports (non-opening windows) on both sides of the boat for some time. Specifically the three sternmost.Recently I removed the ports, disassembled the frames and glass, cleaned everything,located the best matching gasket I could find, reassembled the glass/gasket/frame, cut away the gasket on the outside of the glass( because the fit wasn't that good) and applied a professional glass silicone sealant to the glass/frame joint. I then reinstalled the assembly using a professional glass installation caulking tape( thick, sticky and mallable) between the frame and the cabin deck sides. When I secured the port by attaching the inside frame everything pulled tight and the outside caulking tape squeezed out a little around the frame like one would expect.We just had Tropical Storm Barry drop a bucket of water and three of the six leaked, AGAIN!What kind of ports are they( original), and how do I fix them from leaking ?
